kmacht wrote:If you are going to change it then consider eliminating it and putting in something better. I never liked the idea of the finger strainer in the bottom of the tank. The strainer idea is good but the location sucks. If it were to slowly clog there is no good way to inspect it on the walk around to clue you in that there is a problem. I have a clear filter just after the tank exit and past the shutoff valve that I can visually inspect before each flight.
Users browsing this forum: No registered users and 73 guests
