Page 1 of 2
Solid Throttle Cable with Aeroconversions Quadrant
PostPosted: Sun May 28, 2017 12:59 am
by Direct C51
I am using the Aeroconversions Throttle Quadrant with my MA3-SPA Carb and replaced the braided cable with a solid .078" ACS throttle cable. I am having trouble terminating the solid cable at the throttle lever. The Aeroconversions method of passing the cable through the bolt and tightening it between two washers just doesn't work with the solid cable. No matter how tight, it will eventually slip. Has anyone used the Aeroconversions throttle quadrant with a solid throttle cable? Any ideas would be greatly appreciated.
Re: Solid Throttle Cable with Aeroconversions Quadrant
PostPosted: Sun May 28, 2017 1:44 pm
by Fastcapy
I used a wire grip and I believe a small rod end. I can take a picture in a bit.
http://www.aircraftspruce.com/pages/ap/ ... regrip.php
PostPosted: Sun May 28, 2017 1:47 pm
by Direct C51
Thanks Mike. I am interested in seeing the pictures. I don't see how you could fit a wire grip and rod end with the rest of it being stock since the lever nearly touches the quadrant mounting plate at idle.
PostPosted: Tue May 30, 2017 7:34 pm
by Direct C51
Mike and I can't be the only ones using solid cable with the aeroconversions quadrant. I could really use some ideas here as I am at an impass. Thanks.
PostPosted: Tue May 30, 2017 10:07 pm
by Fastcapy
PostPosted: Tue May 30, 2017 10:48 pm
by Direct C51
Thanks for the picture Mike. I suppose I should have mentioned that I need the configuration to be pull-open push-closed. There is a lot more room for the rod end and cable clamp in your pull-closed push-open configuration.
PostPosted: Wed May 31, 2017 11:07 am
by Fastcapy
Ok, sorry I was thinking that carb was the same config as mine.
PostPosted: Thu Jun 01, 2017 10:14 am
by kmwoody
I have been using my throttle quadrant for 435 hours with a solid cable, no problems. The original owner put a RC axle stop after the bolt for added safety.
Ken W
Sonex 959
135 hours on CAMit 3300
PostPosted: Thu Jun 01, 2017 9:57 pm
by Direct C51
Ken, have you been using the standard two washer method for terminating the solid wire at the throttle lever?
PostPosted: Thu Jun 01, 2017 11:08 pm
by kmwoody
Yes, just as the instruction sheet shows. If I remember, you are not tightening the cable between two washers, you are tightening the outside washer against the cable swivel stop. The inside washer is just a spacer. You can fully tighten the nut and the swivel will still move easily. You might need a L ,thinner, washer on the inside if there is too much drag on the swivel.
Ken W
