When should I paint?
Postby 142YX » Sun Sep 16, 2012 12:14 am
Nearing the point where my airframe is just about complete, and i am torn between diving right into all of the systems installation, or should i start to work on the cowl and then paint everything while the weather is still warm and do the systems after paint. I know most everybody paints at the very end of the build, but did anyone regret this? Would it have been easier to paint sooner rather than later? Or is there something i am missing that would make this a bad idea?
450 hours and counting..
142YX
Re: When should I paint?
Postby fastj22 » Sun Sep 16, 2012 11:09 am
I'm in the process of painting. I waited until everything else was done. Wanted to get it painted before I move into the hangar and put the wings on. Once all the rivets and bolts are installed, I really can't say it would be too early to paint. Like you, I wanted to get it painted before it gets too cold and I have to heat the garage.
The only negative thing about painting early is you will have to be more careful around the plane.
Postby MichaelFarley56 » Sun Sep 16, 2012 1:38 pm
Everyone will have their own thoughts and opinions on this one, so it's really up to you. The little that I painted was done after the plane was running and I was finishing taxi tests. When you're fitting the cowling you'll be installing and removing it a ton which will probably scratch it up, so I would at least do that first. As for the systems....you can paint first but if you do, I would consider covering the paint up with either plastic or paper so nothing gets scratched. You're correct in that it would be easier to paint now while the wings are off. Plus, once it's flying you won't want to down the plane for a month to paint..you'll be having too much fun flying!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby 142YX » Sun Sep 16, 2012 2:25 pm
Yea i go back and forth with this almost every day. One of the things holding me back was that i wanted to wait as long as possible before riveting the aft bottom skin on.. i will have to commit and do that if i decide to paint.
Fastj22, just out of curiosity what paint system are you using?
142YX
Postby fastj22 » Sun Sep 16, 2012 2:43 pm
PPG Shopline auto paint. Epoxy primer, base color coat, clear top coat.
The control surfaces came out great. doing the bottoms of the wings today.
Postby fastj22 » Sun Sep 16, 2012 2:47 pm
BTW, HVLP guns keep overspray to a minimum and are pretty efficient at paint transfer. You just need a good size compressor to keep up with it.
Postby fastj22 » Sun Sep 16, 2012 8:00 pm
My progress today. Wing bottoms done.
Postby fastj22 » Sun Sep 16, 2012 8:03 pm
More of todays progress.
Postby dbdevkc » Sun Sep 16, 2012 8:48 pm
That's a cool paint scheme!
[color=#800000]Kevin Conklin
Building Waiex #169
dbdevkc
Postby fastj22 » Sun Sep 16, 2012 9:02 pm
dbdevkc wrote:That's a cool paint scheme!
Yeah, I've had a few years to think about it. I always liked the G-Bee and thought the Sonex was a bit boxy. Maybe this will make it look rounder! Lots of sitting with colored pencils on computer prints of Waiexes. And a couple of women at the house to give me the thumbs up/down.
The red was left over paint from my Bahia Red Karmann Ghia. Its a pretty deep red. But I like how it offsets the yellow. The yellow is a stock GM yellow the paint store had. I also had some left over black from a nose repair on my Audi and decided to do the pin striping with that.
I also got some stencils made at a local sign shop that allowed me to use the red for the lettering on all the control surfaces.
