Dynon tpx tso label
PostPosted: Sun Feb 26, 2017 8:23 pm
by WaiexN143NM
Hi all,
Was out to ryan field tucson today, too windy to fly , so was doing software upgrades to our dynon skyview. Version 15.0 . Anyone else have a sky view system with the dynon transponder sv261 or sv262? ( its actually made by trig) the transponder has to be uploaded the new software seperately takes about 6 min. Seperate from the servos, adhrs, ems, skyview box uploads. Those can be done together. After new software loaded, make sure it is showing new software load SW02.04 . Then at home go to www.dynonavionics.com/transponder . Download that page u will get a label to cut out and affix to outside of transponder with clear tape. This needs to be done to be legal and indicate the new TSO authorization. You can down load new softwate update from dynon with a usb stick, or i usually just buy a preloaded stick from dynon $15. Plugs into a usb port on the back of unit.
WaiexN143NM
Re: Dynon tpx tso label
PostPosted: Sun Feb 26, 2017 11:15 pm
by lgsievila
Thanks Michael
