Page 1 of 2
Gusset not required
PostPosted: Sun Dec 11, 2016 3:27 pm
by Concorde
Plan says that no Gusset required for rib number 5 but the W16-05 rib comes predrilled for 07 Gusset but no Gussets included.
Also ribs 1 through 5 fit the spar caps nicely but according to the plan we need to trim them more,why ? Am I missing something ?
Ben
Re: Gusset not required
PostPosted: Sun Dec 11, 2016 3:33 pm
by samiam
You are correct, if I recall there are only gussets for ribs 1-4.
You will need to trim ribs 1-5 to allow them to fit under the spar caps, as outlined in the plans. Rib 1 gets trimmed the most, and they get trimmed less and less through rib 5.
PostPosted: Sun Dec 11, 2016 5:00 pm
by Concorde
The ribs 1-5 fit fine under the spar caps. My kit is # 1684 ,wondering if that makes any difference.
PostPosted: Sun Dec 11, 2016 8:52 pm
by lstinthot
Sounds like the new ones come pre-trimmed. Are they labeled 1-5? If so, I would say move on.
PostPosted: Sun Dec 11, 2016 9:16 pm
by kevinh
lstinthot wrote:Sounds like the new ones come pre-trimmed. Are they labeled 1-5? If so, I would say move on.
yep the new ones come pre trimmed and the gussets are only added on 1-4. 5 just has some holes.
PostPosted: Sun Dec 11, 2016 9:30 pm
by samiam
Wow I thought my kit was good. These new kits must go together fast!
PostPosted: Wed Dec 14, 2016 7:55 am
by Area 51%
You would think so........wouldn't you. The pre-notched ribs are a big help, but the holes in both the ribs AND gussets are NOT! Any time savings were cancelled out for me.
Ben, and anyone else that has not bent their gussets yet, go to the Waiex plans topics, and look up W19 woes. The bends are critical in their placement, and there is a grand solution on You Tube.
PostPosted: Wed Dec 14, 2016 12:46 pm
by Concorde
51%, My Gussetes were perfect match, and the bents turned out very nice. Sorry about 51% didn't see your name.
Thanks
Ben
PostPosted: Fri Dec 16, 2016 10:10 am
by Concorde
Is there any point of making a Gusset for rib 5 ? Or it's just some extra weight with no real benefit .
PostPosted: Fri Dec 16, 2016 10:29 am
Ben,
Weight is the enemy. Don't add stuff not called for as a general rule. Ribs are not highly stressed members either.
