Aircraft lift
PostPosted: Fri Nov 25, 2016 11:22 pm
Hey guys,
Has anybody built an aircraft lift for their Sonex? The commercial lifts seem like overkill for our under 700# airframes. It seems a two post car lift could be adapted as a Waiex lift. Or, something new could be engineered. I am looking for an alternative to finding a new, smaller renter.
Re: Aircraft lift
PostPosted: Sat Nov 26, 2016 2:46 am
by peter anson
Not sure if this is what you are after Bryan, but this one was made from left-over junk so effectively cost nothing. It's very stable and could be made more compact by having removable handles.
I have only needed to use it a few times.
Re: Aircraft lift
PostPosted: Sat Nov 26, 2016 6:07 am
by sonex892.
This might give you an idea Bryan.
http://www.morganaeroworks.com.au/storagelift.html
Re: Aircraft lift
PostPosted: Sat Nov 26, 2016 9:45 am
Peter,
I have one similar we used when rigging the wings. I think we will use it again when doing the brakes. No way will the C182 fit under there though!
Steve,
One of the neighbors has a similar one. It is a clever design.
Re: Aircraft lift
PostPosted: Sat Nov 26, 2016 7:42 pm
by Gripdana
I use the KISS lift. It is a 2" x 4" that spans the fuselage at the landing gear and a floor jack in the center to lift the plane. Works great for me.
Re: Aircraft lift
PostPosted: Sat Nov 26, 2016 7:50 pm
by peter anson
Oops, sorry. Didn't realize you meant a storage lift. I think your main problem is that the usual commercial lifts are designed for tri-gear aircraft.
Re: Aircraft lift
PostPosted: Sat Nov 26, 2016 7:54 pm
Peter,
I think I was not very clear, but yes I am looking for a storage lift.
Re: Aircraft lift
PostPosted: Wed Nov 30, 2016 2:58 am
by rick9mjn
there is a lift listed on "barnstormers.com" under /airport property , under /hanger...and it look like it is in OHIO......here is a copy of the AD. ,,we will see if it paste on to this forum.....AIRCRAFT HANGAR LIFT • MAKE OFFER • Airplane Lift for a Tail Dragger. Free standing on hangar floor. 1 Ton electric hoist 110V. All steel newly built lift. Fully adjustable and can also be converted to nose gear plane. Can be disassembled for shipment. Located at KCGF. Details available. Make Offer ! 216-218-2277 • Contact Scott L. Alperin, Owner - located Mayfield, OH USA • Telephone: 2162182277 . 4404616390 . 4404732244 • Fax: 4404612990 • Posted November 6, 2016 •
....good luck good day rick
