'Y" Tail twist
'Y" Tail twist
Postby fallalloveryou » Tue Aug 23, 2016 2:12 pm
Hi,
I just finished doing the final rigging and discovered that my "Y" tail is about 3 degrees off which is likley do to a slight built-in twist in the fuseladge.
Does anyone have any knowledge on how this may affect the flyability of the plane?
fallalloveryou
Re: 'Y" Tail twist
Postby MichaelFarley56 » Tue Aug 23, 2016 4:09 pm
You'll probably want to check with the factory tech support for an official answer on this one, but my guess is that you won't have any issues and your plane probably won't know the difference.
Good luck!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Re: 'Y" Tail twist
Postby N111YX » Tue Aug 23, 2016 6:26 pm
Hopefully, it's twisted the proper way to counter engine torque in cruise. Zero rudder deflection from not needing a rudder trim tab would be cool. If it's the other way then...oh well... :D
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1100 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Re: 'Y" Tail twist
Postby fallalloveryou » Tue Aug 23, 2016 10:41 pm
I would think that it only would be felt when the elevator is used. i.e. with forward elevator slight yaw to the left and aft elevator slight yaw to right. Does that make sense?
fallalloveryou
Users browsing this forum: No registered users and 124 guests
