Taper pin length for 7/8 tubing
Postby Darick » Fri Aug 12, 2016 9:28 am
I'm not sure what length to order for the SNZ C03-05 elevator connection tube. I'd like to use taper pins instead of AN3 bolts. Would 1" (AN386-1-8) be the correct length?
Does anybody know if the tapered reamer is still in the tool loan program?
Darick
Darick Gundy
Sonex #1646
N417DG
First flight! 10/21/2017
Darick
Postby Sonex1517 » Fri Aug 12, 2016 8:20 pm
Darick
Bryan Cotton has the tapered reamer I believe. Check on Sonexfoundation.com for the technical article and it has the specifics of the taper pin. Let me know if you don't find it.
Robbie
Users browsing this forum: No registered users and 137 guests
