SonexIronman Blog
SonexIronman Blog
Postby jjbardell » Tue Aug 02, 2016 1:01 pm
After Oshkosh I have received several requests for more information on my panel design, a/c unit and aux fuel tank. So I thought it would be fun to start a blog!
Feel free to read athttp://www.sonexironman.wordpress.com
N83LJ - Sonex #0864 (SOLD)
jjbardell
Re: SonexIronman Blog
Postby Bryan Cotton » Tue Aug 02, 2016 1:44 pm
Thanks for posting Josh! At first I thought it was Paul Dye's blog but then I remembered he is Ironflight. I'd like to know more about your nav light mount. I was thinking of doing something similar if I understand your pictures.
Postby jjbardell » Tue Aug 02, 2016 2:08 pm
Thanks Bryan! I purchase wing tip mounting brackets from knutzleman adapter plates and mounted my strobes to those. The .032 6061 plate was made and simply cutout with two nutplates then attached to the fiberglass wingtip. I soldered my wires instead of putting connectors on them and left about 12" inside the wing to reduce a possible point of failure. This allows me to pull the plate off, access inside whenever I need.
Keeping them high and out past the wing itself so it is visible from above is important part of the FARs for night/IFR flying. Be sure you check your FARs on that.
http://www.kestrobes.com/cat2.htm
Hope this helps and let me know if you have any questions.
Bryan Cotton wrote:Thanks for posting Josh! At first I thought it was Paul Dye's blog but then I remembered he is Ironflight. I'd like to know more about your nav light mount. I was thinking of doing something similar if I understand your pictures.
jjbardell
Postby MichaelFarley56 » Tue Aug 02, 2016 5:21 pm
Thanks for taking the time to create this Josh!! I appreciate your work and look forward to seeing your A/C system!
I'm glad to see your airplane at OSH...it looks great!!
Thanks again!!
Waiex #0056 - N569KM
Jabiru 3300A #1706
Postby Jlogan1 » Mon Jun 11, 2018 4:02 pm
Hi Josh, looking at adding an aux tank to our jabiru 3300 trigear. would love to see photos of your set up. feel free to text me at 574-536-0068 or email at jake.logan@stairsupplies.com
Jlogan1
