fastj22 wrote:Which efis? Usually an alarm light is wired between the efis alarm lead and a 12v source. When the efis senses an alarm condition, it grounds the circuit thus illuminating the light.
Check your wiring to make sure it isn't prematurely grounded.
Also check all your parameters on the efis to see if something is causing the alarm condition but isn't a parameter you are displaying.
SonexEZ wrote:fastj22 wrote:Which efis? Usually an alarm light is wired between the efis alarm lead and a 12v source. When the efis senses an alarm condition, it grounds the circuit thus illuminating the light.
i will look today
SonexEZ wrote:I replaced the harness today still have a red light , I wanted to hook up the front two CHT all cylinders are very near the same in temp ,going to check alternator tommorow and regulator output
Users browsing this forum: No registered users and 35 guests
