by achesos » Wed Nov 18, 2015 9:46 pm
Originally, I had single conductor wire installed through rubber grommets in each rib, and closed the wing. Then I bought strobes instead, so I needed multi-conductor.I used 1/4" ID vinyl tubing and placed in the lightening holes. I hope to build up some carbon fiber wingtips someday, so once I open them back up I'll be able to route and constrain both ends - but in the meantime, the tubing will give plenty of chafing protection even though it isn't tied down at each rib. This small increase in mass adds up, but I'm not going to sweat it - I prefer the thought of the increased safety with the strobes over a few ounces spread across the width of the entire plane.
Sonex N857SX
AeroVee, Taildragger, Dual Stick
