iEFIS / V6 / trig 22 wiring help needed
Postby jjbardell » Tue Oct 06, 2015 10:44 pm
Purchased all the hardware and quick wiring kits from MGL. I have no electrical experience and am looking to see if anyone would be able to assist via call, wiring diagrams or FaceTime on how I wire all these devices together.
I'm really struggling with:
- trig wiring harness
- PTT wires
- stay alive
- rx/tx switching
Any help would be greatly appreciated. PM if you're willing.
Thanks in advance.
Josh
N83LJ - Sonex #0864 (SOLD)
jjbardell
Re: iEFIS / V6 / trig 22 wiring help needed
Postby Rynoth » Wed Oct 07, 2015 8:59 am
The PTT wires are just a simple switch to ground. You take the ptt wire, run it to one side of your ptt switch, and the other side goes to ground. When that wire is grounded (button pressed) it puts the V6 into TX.
By stay alive do you mean the "hot" +12V to the iEfis from the battery? I just put a ring terminal on an in-line fuse holder with a 5A fuse, secured that to the lug on my master contactor (on the "hot" side) and ran a wire from there to the iEfis. (Incidentally, I used this same wire to a 12V socket in the cockpit so I could hook up a battery tender without removing the cowling.)
I'm not familiar with the trig.
