fastj22 wrote:An extra 5 gallons of fuel makes for a lot of options here in the west.
People keep talking about the weight of fuel and the weight of the tank. But you're not just adding a tank; you're adding a whole extra fuel system to the airplane! Sure, it doesn't go to the engine - it stops at the main tank - but its still a system with multiple components. I don't see many people discussing this. You need to include the weight of plumbing, fuel pump, vents, and fasteners.
These all add weight. And are you going to bring any spares or repair items in case these break or develop a leak during a trip? As a rough planning number, I would add at least 5 lbs of system weight to Steve's (ingenious) "6 lb tank" - making it more like 11 lbs for the system.
While extra fuel is always nice, consider the useful load of the Sonex...
SCENARIO 1: You want to go a long way with a passenger on a single load of fuel
If you're thinking of flying several hundred miles away from your home airport, you're probably going to be carrying two adults, plus some baggage, plus a normal Sonex load of fuel. That already puts you at or very near gross weight - even
IF you specify a higher gross weight than Sonex Aircraft recommends. Let's do some Math:
650 lbs empty weight (somewhat optimistic considering the weight of most Sonexes)
360 lbs Humans
30 lbs baggage, tools, emergency kit, etc
90 lbs fuel
= 1130 lbs (which is already 30 lbs over factory gross)
How comfortable are you with flying at/above gross weight? Are you OK with only getting 400-500 fpm climbs? Have you considered things like density altitude and turbulence? Although I often fly at an airstrip on the west coast (at low altitude), I just spent a week in Idaho where the airport was at 5900' MSL and with the temp the DA was over 8000'. The takeoff run in my (non-Sonex) aircraft was
double what I was used to!
You mentioned flying in the west, where many airstrips are narrow and relatively short, the air is rougher, and climb performance is important. Will your extra fuel-tank actually be useable in this scenario... Honestly? Is that 1 hr of extra flying time before a refuel worth all of the trade-offs? Will your passenger actually be OK flying for 3+ hours without a break? (And have both of you actually flown in a Sonex in order to know that answer for sure?)
SCENARIO 2: You want to fly somewhere solo and not have to stop for fuel as often
Compared to the first scenario, you've got an extra 100-200 lbs of load to work with. You also have free space on the seat.
For this scenario, at least a few Sonex pilots have used the
"Turtle Buddy" from Turtle-Pac. Its fully removable, nearly doubles your useful range, and sits on the seat. Unlike the baggage compartment, the seat is designed to take this kind of weight and this fuel system will affect your CG in the same way that a passenger would.
--Noel
