sonex892 wrote:Andy, Its probably ok. SNX-F11 detail B at the bottom centre of the page, clearly shows these holes are not on the same line as the rivets. Bolts are 3/8" from the angles edge. The rivets I think from memory are on the centreline of the angle. Did you chamfer the internal corners on the splice plates where the plates meet each other?
Sonex 892
3300 TD 80hrs
I'm not sure once I open up those holes to 3/16 that there will be anywhere near 3/8 to the edge on mine.
3/8" from the edge of the angle to the centre of the hole
Steve 892
falvarez wrote:If you haven't updrilled yet, you may be able to move the center of the hole. I was able to move some holes slightly by drilling a good hole in a piece of scrap 3/16" aluminum, clamping the scrap 3/16" aluminum where I wanted the center of the hole to be (of course you can only move the hole so far), then starting the updrilling process. Taking my time with this approach I've been able to move the center to something more suitable.
Hope this makes sense.
Frank
Sonex #800 - Scratch Building
Middleburg, FL
