Close Enough or Do Over?
Posted: Fri Oct 21, 2011 9:38 pm
Hey Ya'll...
I just put the upper crosstie on the front of my forward fuselage. Pre-drilling, it was exactly 32" wide at the outside of the longeron, per plans. After drilling, it seems to have shifted a hair, and now the width is about 1/16" wider. This isn't much, but since this part helps set the square of the fuselage, I'm nervous.
Does anybody know if 1/16" on this part is going to cause a problem? I test fit the lower firewall, and it fits well, but if you look closely you can see it's very tight against the hinges at the bottom, but there is a very small (I'm guessing 1/32" ;) ) gap between the firewall edge and the hinge at the top on each side.
Thoughts or suggestions? I don't really want to buy a new crosstie of a 1/16" error, but I don't want this to cause troubles later fitting the engine mount or something.
