radfordc wrote:You said, "A surprise for this "Hershey Bar" flat wing was how the air separated and the wing stalled in the wing
root first and the wingtips maintained airflow and aileron authority without the help of twist or washout
in the wing. "
I'm not surprised at all. Every description of stall characteristics of a rectangular wing that I've ever seen indicates that the stall progresses smoothly from the wing root to the outer portion of the wing.
https://aviation.stackexchange.com/ques ... t-the-root
509sx wrote:It occurs to me that a place where almost all legacy Sonex birds could use a couple of VGs is the wing root/body side junction. Here one would want to use the VGs to create co-rotating vortices to bring high-momentum air down into the corner. The VGs, then, would be angled with leading edges towards the intersection, maybe two on the fuselage and one or two on the wing. The problem is setting up so you can tuft the intersection and see the tufts. I sure am not keen on putting an expensive GoPro out there on a suction cup!
Users browsing this forum: Google [Bot] and 51 guests
