DCASonex wrote:GRT is definitely worth a look, I think you will find them very economical, and they have had very good customer support.
pappas wrote:Benefit per buck for high-quality equipment that is easy to learn and use....... My vote is Dynon.
lakespookie wrote:I am going Garmin and IFR capable although i dont plan on any hard IFR flight in the sonex due to engine choice and its stability, That being said Dynon and Garmin both have Backup instruments that basically have everything you need in an emergency if you lose the efis to put it on the ground safely + the sonex really is a VFR platform, as examples i am installing a G5, and dynon has a similar product in the D10 if you go with one of the other options a Blaze single can serve as a backup instrument with similar capabilities.
AstroAussie wrote:lakespookie wrote:I am going Garmin and IFR capable although i dont plan on any hard IFR flight in the sonex due to engine choice and its stability, That being said Dynon and Garmin both have Backup instruments that basically have everything you need in an emergency if you lose the efis to put it on the ground safely + the sonex really is a VFR platform, as examples i am installing a G5, and dynon has a similar product in the D10 if you go with one of the other options a Blaze single can serve as a backup instrument with similar capabilities.
If you dont mind, do you think you can make a post about your ifr panel and the plans? I have a dream of doing this too but I have heard concerns due to the weight of it all. I also don't plan to do hard IFR stuff but living on the coast here in california and trying to get into an airport thats has low butts, better be safe than sorry.
Users browsing this forum: No registered users and 101 guests
