Electric flaps , brakes for legacy sonex
Re: Electric flaps , brakes for legacy sonex
Postby dbdevkc » Wed Sep 30, 2020 4:36 pm
Jim,
I am also interested in your design for those toe brakes - if you can share measurements or plans. I am also trying to understand how you have them fastened/pivoting on the pedals.
[color=#800000]Kevin Conklin
Building Waiex #169
dbdevkc
Postby WaiexN143NM » Wed Sep 30, 2020 6:02 pm
hi all, jim, kevin,
they look kevin to just go inside the bottom round tube, alum angles on back side of rudder sq tube.
question for jim, would it be better to run a full length bolt per rudder bar thru the bottom to capture the alum round tubes and angles?
and are the backside alum angle pieces long enough? longer woud give you more leverage . is there enough leverage on the heager master cylinders?
Postby jowens » Mon Oct 05, 2020 10:30 pm
I believe there is enough leverage. This is the plan of the original cylinder side. I have since cut off 9/16" so I don't have to raise my heals to apply light brakes. I have about 140 flights in six months on the toe brakes.
Jim Owens
jowens
Users browsing this forum: No registered users and 145 guests
