N111YX wrote:It's not all about performance. I'd gladly give up 20 horsepower, 30 lbs of weight, and a few more $ for a TSO'ed engine. If I only flew over Kansas I might think along your lines but then again I'm probably in the minority.
Is an RV12 some sort of standard reference? That design would not influence me one bit if I had the designers pen.
NWade wrote:N111YX wrote:It's not all about performance. I'd gladly give up 20 horsepower, 30 lbs of weight, and a few more $ for a TSO'ed engine. If I only flew over Kansas I might think along your lines but then again I'm probably in the minority.
Kip -
Well you probably think I'm crazy, then. I fly over the rugged North Cascade mountains with a glider - no engine at all! ;-)
As for a TSO'ed engine: I'm curious to hear you explain what appeals to you about a TSO'ed engine. Is there some tangible benefit or feature that a "Certified" engine provides (which other Sonex-approved engines don't)?
And I cite the RV simply because its one of the most-successful LSA aircraft out there. You may not like its looks (I know I don't). But the entire RV series in-general is the "gold standard" in Experimental Aircraft, in terms of both quantity built and their reputation for quality. I also happen to fly with "Van" himself each summer (that glider thing again). Its given me an opportunity to bend his ear and have some wonderful evening chats. I had a really illuminating talk on the merits of the Jab3300 versus the Rotax, for example. Van is a conservative chap when it comes to safety and engineering; yet even he doesn't recommend an O-200 for any of his aircraft. If you don't like Vans as a reference, look at the other major kit-makers. None of the designs over the last 15 years recommend an O-200 for a ~100HP application. They all pitch a Rotax, Jab, or UL Power as the first/best solution.
--Noel
planeolbob wrote:Hi Everyone,
I can now share with everyone a little project I shared with Jeremy in July of 2012. As you all know I have been building and flying my Sonex since 1999. In every way it is a great aircraft. The only thing I wished it had was a little more shoulder room. So beginning in early 2012 I started a design study I called the "WideX'.
We talked from time to time and in the fall of 2014 he told me that things were starting to move on expanding the product line. I must say that in typical Sonex Fashion they have gone far beyond expectations and the B Models will be a great hit. I can't wait to sit in one.
Bob Mika
N178KT
PS Now, if I could just find an old set of uncut spar caps............
Users browsing this forum: No registered users and 146 guests
