WesRagle wrote:
It's kind of hard to tell from the pics, but there is a preferred edge to over lap. The edge that you want to cover up is the edge with the extra stitching. For some reason it leaves a lot of little frays.
Rynoth wrote:
That's interesting, I'd never considered overlapping one edge vs the other and that does make sense. However as soon as the engine is run the wrap is going to "bake" and harden, those frays will crisp up and I don't think there's any worry for unravelling down the road (probably looks better without them though.)
I could never figure out SS zip ties either (is a special tool required?) Ended up using hose clamps instead (a few extra ounces?)
Also a quick tip, if you're installing EGT probes in the exhaust, install them first, then wrap. Otherwise you may end up with a little exhaust leak if the probe is held off of the exhaust by the wrap.
