NWade wrote:Although it's another item to wear out and another set of fittings to possibly leak... ;-P Everything is a trade-off!
DCASonex wrote: I had sight tube routed along edge of panel and down side of fuselage. gave readings for bottom of tank. BUT I removed it after two years when found tubing had gotten so hard it was brittle. It actually snapped in half when removing it. My Princeton prob has worked well connected to the GRT Sport SX, but I use only Avgas, and the red cube flow sensor into same Sport SX has also been reliable so no longer saw need for sight tube that looked to present its own hazards.
daleandee wrote:I really considered what Sonex did here:
A nice slot in the panel to see the tank through. Perhaps a light on the rear of the panel with a momentary contact switch to see the level with ...
Dale
N319WF
Users browsing this forum: Google [Bot] and 46 guests
