mike.smith wrote:Gunther wrote:Hello to all. How long does it normally take you (and a helper) to INSTALL your Sonex wings?
Thank you,
Gunther
I'll let you know after tomorrow!!
#439
Rynoth wrote:I would argue that a logbook entry is required, just as if you performed an oil change or valve adjustment. But no A&P required as Robbie said.
radfordc wrote:Rynoth wrote:I would argue that a logbook entry is required, just as if you performed an oil change or valve adjustment. But no A&P required as Robbie said.
Is installing the wings "maintenance"? If you remove the cowl and then reinstall it does it require a log entry? What about inspection panels?
Users browsing this forum: Bing [Bot] and 93 guests
