BRS wrote:N111YX wrote:Bryan, my gear bolts go in pointing aft, washers make up the distance to the firewall, and the castle nuts are on the cabin side of the firewall. It works well. The torque on the nut is minimal so there is no need to go so tight as to crinkle the firewall. There seems to be a good seal from the washers.
Kip, Do I understand you correctly? You are using castle nuts and a cotter pin on the cabin side - right? I like that. These bolts are loaded strictly in sheer and don't really need to be tight (correct me if I'm wrong). Thus a castle nut could be put on just tight enough that the, un-held, bolt doesn't rotate. Then just install a cotter pin.
