Rynoth wrote:Just some food for thought (and to muddy the waters a bit I suppose), but the way the plans call for wing rigging (i.e. not pre-updrilling the spars) has you rig the rear spars to the fuselage prior to updrilling the main spar holes..
Bryan Cotton wrote:I clamped my spars to the front fuselage attach angle before I drilled. No slack.
I piloted a 1/4" hole in my rear angles then finished up the drilling on a press. I had riveted the pieces together with flush aluminum Avex rivets I had, then drilled them out after. Came out great.
Area 51% wrote:Can't speak for Bryan, but that's what I did. Then pushed the drill bushings in from the front to drill the 1/4 hole in the rear attach angle.
I up-drilled the 1/4in hole in the front attach angle with the wings removed and using an alignment block. Very similar to what Bryan used. I can send you a picture.
