builderflyer wrote:If the 40s are as cold as your winter temps get then what has worked for me is to first utilize Aeroshell 15w50 oil year round and second to carefully direct hot air from a heat gun into the cowling outlets for a few minutes before attempting to start. If you have an older 3300 like mine (with the black starter motor ) then you'll always be at a disadvantage for starting, cold or hot. I'm not into using a lithium battery and the Odyssey battery I've used for years has been marginal in its cranking power. So in the past year I've been using a Deka battery (ouch, it's heavy) and it's increased cranking power has more than offset the additional weight penalty.
Hope this helps,
Art,,,,,,,,,,,,,,,Sonex taildragger #95,,,,,,,,,,,,,,,Jabiru 3300 #261
tx_swordguy wrote:https://katsblockheater.com/block-heaters/all/engine-oil-pad-heater-250 I have the 4x5 on my jab 3300. just clean the side of the oil pan real well (i used acetone and let it dry real well) stick it on and press all the pad down well. Then put some hi-temp silicone around the edges and go. I have had mine on for a yr no propblems, others 4+ yrs no problems. after a 30ish degree night and getting to the airport around 10-11 I plug it in first thing, do my preflight (20 min or so) the oil will routinely read 80 degrees at start up. It will then cool off a couple of degrees (mid 70s) until the engine is warmed up. I like it, it works for me and no trouble starting.
Mark
oh and ps, you can trim the edge but be very careful or you will cut the wires that heat the unit. I would not trim more than 1/8 inch or so off the edge if needed.
Bryan Cotton wrote:In the PA28R180 I used to fly, we would put a 100W trouble light underneath. Foam bird blockers in the inlets, and a blanket on top. Ran it 24/7. Made a difference.
Users browsing this forum: No registered users and 45 guests
