mike.smith wrote: On the Sonex, even if you have the top-mount oil cooler (as I do) Sonex recommends leaving the lower cowl opening to get air running under the oil sump plate.
Rynoth wrote:Is the consensus here that 230 degrees is too hot
Rynoth wrote:Furthermore, I have "heard" that higher oil temp readings may be a result of the temperature sensor itself(mounted on the forward-left-bottom) might be getting hot and running a little air over it may result in lower indicated oil temp, even though this probably doesn't change the actual temperature of the oil itself much.
WesRagle wrote:
I've never cut into one of these but I assume (I'll do a lot of that in this post) that there is a thermistor connected between the terminal on top of the sensor and the sensor body.
Notice that there is no thermal barrier between the "nut and threads" portion of the sensor and the portion of the sensor that is immersed in oil.
Users browsing this forum: No registered users and 65 guests
