Spaceman wrote:
Now I am trying to confirm I have the correct length set, and it appears to be way off! With the forward fuselage level, the bottom edge of the lower longerons is 617mm off the floor, and the center of the axle at the outboard end is 160mm from the floor. So the end of the axle is 457mm, or 18", below the fuselage floor. The plans call for it to be 16-43/64" (424mm)!
N418SX wrote:Just a question, does anyone wheel land their sonex?
That is exactly what I measured, 18" below the fuselage with the top main gear 1/4" hole placed as per the plans (1/2" from top end). I have no desire to hack off a chunk of each leg to make up the 1.3".
