N814W wrote:Thanks for the heads-up on the DIENQ dimple dies gents - much appreciated! On the Cleveland "simple dimple dies", should one go with the 3/32" dies and dimple from #40 pilot drilled holes and then drill to final size, or get the 1/8" dies and dimple to final size from a larger? hole as described by Mike above?
rizzz wrote:Here’s my 2 cents,
I used the Sonex dimple dies for all dimpling required and experimented with different drill sizes to get the best result.
In the end I found that drilling at #34, deburring and then dimpling to give me the best results (drilling at #32 before dimpling still leaves too large a hole I found).
You’re left with a perfect dimpled hole which will 99% of the time accept a rivet as-is, only sometimes a little extra enlarging using a #30 bit was required.
Users browsing this forum: Bing [Bot] and 42 guests
