by Sonex1517 » Mon Jun 01, 2020 10:13 pm
While it may be safer for me to discuss this November’s election, the current events in America, religious preferences, and sex all once, I will post some facts about my VG testing. I am not trying to change anyone’s mind. I am reporting what I learned in my airplane.
I installed the kit from Aircraft Spruce this past winter. I have done some fairly extensive testing, and this past weekend during my WINGS training, my CFI and I wrung out the Sonex thoroughly.
First thing is that prior to this, my Sonex would actually stall. It made loud oil can sounds just as it did, then the nose dropped. This no longer occurs in the same airplane, no other mods that could change it. The airplane will not stall. It wallows, it wiggles, it washes around. No break at all.
I release the slightest amount of back pressure and it’s flying again. Most interesting to me was no oil can sound at all. It used to be very pronounced.
Second thing is in a turning stall, it no longer threatens me with bad behavior. I will be the first to admit I had not been aggressive with this test in the past. Sunday we did turning stalls with the stick in my lap. No bad behavior.
In both of these tests my airspeed indicator was pegged at the bottom and my LRI danced far down in the red.
Third thing was Minimum Controllable Airspeed (MCA). This blew me away. I can turn the airplane at MCA like never before. We practiced an engine out procedure and lost less than 300’ - more like 250’. This does not change my personal decision of no turning back below 800’ AGL but it was eye opening. I was able to make an aggressive left 45° bank, rudder almost to the floor, at 70 mph with the stick back.
In my opinion, the LRI truly pays off at MCA. I can play around and know when I have lift remaining.
Finally, landings. I am able to land my Sonex more consistently, more smoothly, and - most important for me at 1C5 with a nearly constant crosswind - maintain better control with the VG’s, especially for whatever reason with a crosswind from the right. I was finally able to successfully wheel land the airplane, something that eluded me previously. I’ll blame my poor piloting skills for that.
Last weekend I was able to keep it on one wheel longer than I ever was able to in a strong crosswind.
I installed the VG’s on the wings, the horizontal stabilizer and the vertical stabilizer per the kit plans.
Clearly this is a somewhat touchy subject. But in the interests of factual data, I wanted to report my own experience. Your experience and opinion may vary greatly.
