B and C voltage regulator
Postby T41pilot » Sun May 03, 2020 9:04 pm
Has anyone tried the new B and C voltage regulator yet? I'm in the process of doing a few Firewall things and am curious whether their new voltage regulator provided a higher output at low rpm and maybe provide a charge or at least break even battery voltage instead of a discharge during taxi. It's costly, but with the built in crowbar it simplifies things and may be less prone to failure. Before I spend the money, I wouldn't mind some feedback.
Gregg Kaat
Sonex B #0014
T41pilot
Re: B and C voltage regulator
Postby WaiexN143NM » Sun May 03, 2020 10:31 pm
hi gregg, all,
ive been watching these too. are you looking at the LRC-14? $180. plus they have an install kit for $45.
interesting to note is they reccomend to install on the cockpit side of the firewall. away from vibration and heat and moisture. built in low voltage warning , and over voltage crowbar.
jeff schultz mentioned these a few months ago. any thoughts jeff?
greg let us know if you get one and if you like it.
Postby T41pilot » Mon May 04, 2020 11:36 am
Hi Michael
Yes, that's the one I'm looking at. My guess on the cockpit side of the install is that the additional electronics in the Regulator can not stand the added heat from the engine compartment. Our standard regulators apparently generate a lot of heat and aren't too happy with the additional engine compartment heat as it is. That may be why they are failing. I think we are loading them at capacity on a regular basis. I'll probably get a B and C anyway even if I don't get any feedback but it looks like end of summer before My engine is running. I still have a ton to do yet so I won't be able to generate a report any time soon.
Gregg Kaat
Sonex B #0014
T41pilot
Postby WaiexN143NM » Mon May 04, 2020 12:31 pm
Hi gregg,
yes i’d go w the b& c new unit. it s should last forever. i think your right about the heat. i have blast tubes to my coils, jab 3300. on my to do list is a blast tube to the regulator.
keep at it and happy building!
Postby sonex1374 » Mon May 04, 2020 1:23 pm
The new B&C voltage regulator designed for permanent magnet alternators is the "AVC1", and B&C lists it for something like $260. According to their marketing department it was due to hit the website but the coronavirus situation interrupted that effort.
B&C says it will be available on the web shortly (time???), and that initial user feedback has been extremely good on the unit. I think this is an ideal option for all Jabiru, AeroVee, Revmaster or Rotax users that are looking for a replacement VR.
Jeff
Jeff Shultz
Sonex TD, 3300, AeroInjector
Kansas City, MO
http://www.sonex604.com
sonex1374
Postby gammaxy » Mon May 04, 2020 1:40 pm
Gregg,
From your posts, it seems you have an Aerovee? Double-check, but my interpretation is the LRC-14 regulator is not intended for permanent magnet alternators like the Aerovee has. Even if it works, there's no field windings for it to control to increase the voltage at low RPM, so you'll be missing out on a primary benefit.
I'm not sure how common regulator failures are on the Aerovee. I have one installed in the recommended location without dedicated cooling and haven't had any issues with it.
Edit: I see Jeff's post now, the AVC1 sounds more like what Gregg was probably originally referring to. https://bandc.com/wp-content/uploads/20 ... -11-20.pdf
Postby WaiexN143NM » Mon May 04, 2020 3:52 pm
hi jeff, chris, all,
thanks for the info and update. i thought the LRC-14 was the new one. i will wait for the AVC-1 to hit the webpage.
i plan on getting one. gregg did you see jeff’s and chris posts?
thanks jeff!
Postby sonex1374 » Mon May 04, 2020 4:55 pm
I confirmed with B&C that the AVC1 is available and ready to purchase. Until the website is updated, you'll need to contact sales directly (Nathan Bainbridge, nathan@bandc.com). I've attached the product info flyer as well.
Jeff
QuickFacts_AVC1_2020.pdf
(1.1 MiB) Downloaded 466 times
Jeff Shultz
Kansas City, MO
sonex1374
Postby pappas » Mon May 04, 2020 5:57 pm
I'm not clear on how this regulator enhances low rpm charging output from out little 20 amp stators. Whats the scoop?
Lou Pappas
Phoenix, AZ
RV-7A Flying (2024)
Waiex B Turbo (2016)
RV-8 (2009)
Waiex Legacy 3300 (2007)
Hiperlight SNS-9 (1991)
Falcon Ultralight (1989)
pappas
Postby T41pilot » Mon May 04, 2020 6:10 pm
WaiexN143NM wrote:hi jeff, chris, all,
thanks jeff!
Yup Michael. I thought the LRC was the new one too. Glad Jeff set the record straight on that one. I'll be purchasing it and hope that it's reliable to justify the price.
Gregg Kaat
Sonex B #0014
T41pilot
Users browsing this forum: No registered users and 72 guests
