by MichaelFarley56 » Wed Aug 12, 2020 8:30 am
At this point dual sticks are not an option for the B model unless you want to engineer the entire setup yourself. On the A models the area under the seat pan has room for a welded stick assembly that supports dual sticks. On the B model the seat geometry is different and the area under the seat is full of support ribs.
Anything is possible but if you want dual sticks on a B model it will be an engineering project for you! Thus far I don’t believe anyone has attempted it.
Beat of luck on your build decision!
Waiex #0056 - N569KM
Jabiru 3300A #1706
