Radio noise flightline 760
Postby ncsonex » Sat Aug 04, 2018 4:42 pm
I'm having trouble with static in my flightline 760 radio. Any suggestions?
ncsonex
Re: Radio noise flightline 760
Postby Sonex1517 » Sat Aug 04, 2018 4:52 pm
I have the same radio and had the same problem. My static was only above 2200 RPM and nothing seemed to help. This was with an AeroVee. I am converting to a Jabiru 3300 so we will see if it helps.
What engine do you have and what have you tried to reduce the noise? Is it constant or only above a certain RPM?
Aero Estates (T25)
First flight 10/10/2015
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby ncsonex » Sat Aug 04, 2018 4:55 pm
ncsonex wrote:I'm having trouble with static in my flightline 760 radio. Any suggestions?
I have Jab 2200
ncsonex
Postby ncsonex » Sat Aug 04, 2018 5:55 pm
I have filters and have checked grounds and connections to radio
ncsonex
Postby Sonex1517 » Sat Aug 04, 2018 6:12 pm
Ok, there are several threads on the best methods to address noise. Where is the filter, and what kind is it? Typically an RC filter is the best method - the AeroElectric guide has some great info on where to install it.
If it varies with RPM, it may be ignition noise. If not, it could be from an EFIS or ripple on the DC power.
One suggestion is to take up a handheld radio and see if the noise is in the handheld. If it is, it is likely ignition noise. If the noise is only in the FlightCom then I would start looking at other sources, particularly an EFIS. (Try shutting the EFIS off to see if the noise is gone)
Aero Estates (T25)
375+ hours
Jabiru 3300 Gen 4
Prince P Tip
Taildragger
N1517S
Sonex1517
Postby Gripdana » Mon Aug 06, 2018 10:02 am
I had an issue with noise on my radio. After moving the antenna and chasing down other expensive remedies I was unplugging my iPad and other items charging in the USB adapter in the cigarette lighter plug and the noise went away. I purchased a better adapter and problem solved.
Dana Baker
Scratch Built
First Flight March 8, 2015
Gripdana
Postby lpaaruule » Tue Aug 07, 2018 7:59 am
To Dana's point, a friend of mine discovered the same thing when he had his tablet plugged into the USB charger.
Stratux recommend's this brand, and it happens to be on sale today:
https://www.amazon.com/gp/product/B00VH84L5E/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
Paul LaRue
Sonex N454EE Plans# 1509
Jabiru 3300
First Flight 12/21/2017
lpaaruule
Postby Msing48 » Tue Aug 07, 2018 8:56 am
I have this inexpensive panel mounted USB outlet from Sporty's and have had no problems with my iPhone and/or my iPad mini plugged in.
Experimental USB Panel Mount
6128A
$19.95
Msing48
Users browsing this forum: Google [Bot] and 56 guests
