fastj22 wrote:There is only one antenna for the 1090, the Skyguard TWX Pro is only 978 out, but dual band in. You could tie both 978 (in) and 1090 (in) to one external antenna with adapters and a tee, I did this with my Stratux and it worked. They provide individual whip antennas for the in's that attach to the box. The 978 out requires a dedicated UAT and can't share the transponder one as far as I know. You must provide the UAT. I use a dedicated 978 UAT on the belly for (in) to get the best signal from the ground stations.
fastj22 wrote:Which model are you looking at?
mike.smith wrote:fastj22 wrote:Which model are you looking at?
http://adsb.skyguardtwx.com/wp-content/ ... ver-EX.pdf
See page 4.
mike.smith wrote:This looks promising from Sandia:
http://sandia.aero/wp-content/uploads/2 ... R5_Web.pdf
With the remote option the control head will fit in my existing panel cut-out for the STX-165 transponder. $3,200. And transponder and UAT can share the same single antenna.
WaiexN143NM wrote:Hi mike,
So if the new iLevel 3AW had an optional certified adsb gps hooked up to it , like the new trig tn72, then ?, but your statement of the portabilty, yea so if it can be portable, even if it permanetly mounted to airframe, seems to disqualify it?
Yes john, the product discription is confusing. I wish they would re-write their web page. They say adsb out with a optional gps source. But as mike mentioned, if its portable at all it cant qualify.
WaiexN143NM
Users browsing this forum: No registered users and 27 guests
