by kmacht » Wed Sep 12, 2012 12:40 pm
Night #2 of cutting the canopy. I switched the bandsaw blade to an 18tpi blade and it worked much better. There was virtually no chipping on the edges of the canopy no matter if it was flat to the saw or not. I got both the front side and rear side cut and initially sanded. The front fits near perfectly but for some reason my line on the back side was too big and will need some more trimming. I have found that the belt sander with a 120 grit paper does a good job of sanding the material the last 1/8" down to the cut line. I then followed that up with 150 grit on an orbital palm sander and then finally with a fine grit sanding sponge. The result of that process is a perfectly clear and smooth edge. The sanding belt leaves a semi rough edge and a little bit of melted plastic. The orbital sander removes those rough spots and the plastic to make the edge smooth and the sanding sponge rounds the edges slightly and polishes the edge back clear. It takes me about a 45 minutes to cut, sand, and polish each edge.
I also did some testing with different drill bits on the new material. The first was with a standard drill bit with the material backed up by a piece of wood. It resulted in no cracks. I next tried a standard drill bit with the material unsupported and slightly bent to simulate the side edges of the canopy. It resulted in a small crack/chip on the back edge of the hole just like John descibes in his canopy fitting video. The next trial was with a regular drill bit that had been dulled. It resulted in no cracks either supported or unsupported and bent. What I didn't like though is that once the bit broke through it wanted to pull the drill in because of the flutes on the side of the drill grabbing. Finally I tried a unibit. This resulted in no cracks either supported or unsupported and bent. It also didn't seem to pull at the material and more or less scraped its way through. I think this is going to be the method I use when drilling my holes. Also, as a note it was only around 55 to 60 degrees in the shop last night when I was doing the drill testing. I plan on running the heater to get it up at least to the 80's when doing the acutal canopy drilling.
