Capilo Pty Ltd. - Peter Anson's cool Sonex parts!
Postby Waiex 49 » Tue Apr 19, 2016 12:46 am
Today I received my order from Capilo Pty Ltd. (otherwise known as Peter Anson).
I purchased Peter's fuel vent assembly with a built in check valve. God forbid I ever flip the plane over on landing, this check valve will keep the fuel from running out of the tank. Nicely made product.
I also purchased a set of flap stops. These are nicely crafted as well. The stock Sonex flap stop is that angle piece riveted to the fuselage. My opinion of the stock flap stop is that it doesn't work very well. You can easily raise up the flap with only a slight pressure of your hand. Having a solid up stop for the flaps should keep the plane flying steady and should make rigging adjustments easier.
I have yet to fly with either of these products, but I really like them and would recommend others to consider them for their Sonex aircraft. Peter was great to work with, and he made buying parts from Australia to be a very simple, no hassle process. Great guy to do business with.
You can check out all of Peter Anson's Sonex parts at http://www.ansoneng.com.
Fly safe!
Don Bowen
Waiex 49
Waiex 49
Return to Introductions
