hickej wrote:Double check that the rudder pedals are centered. The deflection should match on the left and right throughout the elevator travel when the rudder is centered.
I found the problem was that I had the fiberglass tips over the aluminum stabilator ends. I put them on the inside and problem was solved. Thanks!
SonexFactoryTech wrote:I found the problem was that I had the fiberglass tips over the aluminum stabilator ends. I put them on the inside and problem was solved. Thanks!
He contacted Sonex Technical Support and provided some requested photos. We had him an answer in 10 minutes and he had it corrected within an hour.
Blue Skies....
Kerry Fores
Technical Support Manager
Sonex Aircraft, LLC
