Stabilator Fairing
Stabilator Fairing
Postby saddler » Wed May 27, 2015 9:46 pm
What did you guys do, if anything, as a fairing around the leading edge and bottom of the stabilators where they meet the fuselage skin? I've seen John Monnet's video about using plumbers putty to fair the leading edge of a sonex tail I this same area. I think I read somewhere that somebody uses the Van's wing gap seal in that area. That is the way I am leaning but was just curious if somebody had a better or different idea?
Thanks!
Sean Saddler
Troy, OH
Waiex #165
First Flight 10/16/2015
https://www.facebook.com/Waiex165?ref=hl
saddler
Re: Stabilator Fairing
Postby kmacht » Wed May 27, 2015 10:04 pm
I used the plumbers putty like described in the video. I was skeptical at first but it could be easily sanded and made a perfect small fairing. The paint even covered and stuck to it well. It has been on there three years and still looks like the day I applied it.
Re: Stabilator Fairing/plumber's putty
Postby aferddaberts » Sat May 30, 2015 1:35 am
Could you fill me in on the plumber's putty mentioned in your article ? What is the brand name and can it be bought at a place like Home Depot ?
AL Roberts
aferddaberts
Postby saddler » Sat May 30, 2015 7:48 am
Here is John's video describing this method.
http://www.eaavideo.org/video.aspx?v=870261092001
Sean Saddler
Troy, OH
Waiex #165
saddler
Postby kmacht » Sat May 30, 2015 10:23 pm
It is not the flexible stuff you use to seal around sinks and drains. The putty you use is actually a 2 part epoxy made for sealing leaks. It comes as a stick. One part is on the outside of the stick and the other is on the inside. You cut off a piece and kneaded it until it is mixed. You have to work quick as it only takes 5 or 10 minutes to harden. A wet finger works great to smooth it out. I bought mine at Home Depot next to the plumbing solder.
Postby ScottM-Sonex1629 » Sun May 31, 2015 8:00 am
Does this type of fairing help with smoothing out the airflow between the stab and fuselage, or is it mostly for aesthetics? I thought about doing this on my Sonex, but with my "red tail squadron" paint/polish scheme it would be a challenge to do.
Scott Meyer
Sonex 1629 - Sold...9/2019
ScottM-Sonex1629
Return to Waiex
