MichaelFarley56 wrote:As far as I'm aware, the three position flap bracket is something you basically do on your own. I'm still debating on doing this, but I think that when I decide to I'll probably use a Dremel cutoff wheel and lots of filing to make it look square. My bracket is a Sonex stock item I ordered and I think the good news is that, if carefully done, I can modify the stock one and add the third detent.
Andy Walker wrote:Is there a template or pattern out there for the three detent flap bracket, along with some decent instructions? I have the normal two detent one made by Sonex as part of the machined angle kit, and I'm not sure how to go about making one that doesn't look like a total hack job. It looks like those shapes would be very hard to make well and uniformly...
MichaelFarley56 wrote:No Andy you got it. The plan is to put a third notch between the two existing ones. Basically, you're adding a 20 degree notch to the already existing 10 & 30 degree notches.
N111YX wrote: If it takes more than one attempt, the 1X1 is pretty cheap by the foot...
Users browsing this forum: Bing [Bot] and 5 guests
