pitot and static location
Re: pitot and static location
Postby Bryan Cotton » Tue May 31, 2016 3:36 am
Kip,
Is it just a light press fit into the phenolic? Another advantage of my opportunity (having forgotten to plumb the wing and provide a pitot-static mount) is that stuff will not be in the way for installing wings.
Postby N111YX » Tue May 31, 2016 9:14 am
Yes, Brian. The 5/16" tube slides (twists, really) into the phenolic as a tight "press fit". After drilling the phenolic for the tube, I found that I had to sand down the pitot tube in a lathe a couple of thousands for the right friction for a tight fit. I thought that if it ever became loose from too many in-and-outs, I could always count on getting a new tube and still have some room to adjust for a tight fit. My pitot still slides in with the same friction after six years.
I'll make a video later today or tomorrow if I remember...
Kip
Jabiru 3300 #1637 and #3035
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1050 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Bryan Cotton » Thu Sep 15, 2016 10:18 pm
Here Adam is copying Kip's idea. The tube I have on hand is 1/4" OD, same size as my ACS wing mounted pitot.
Postby N111YX » Thu Sep 15, 2016 11:41 pm
Sorry if I drifted from this topic. Let me know if you need more info...
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1050 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Bryan Cotton » Fri Sep 16, 2016 7:28 am
No worries Kip! Any thoughts on my 1/4" OD vs your 5/16" OD tube? I am thinking it is unimportant. Also did you choose the RH side for any technical reason? Finally I assume the plastic tube is from Home Depot's aviation aisle. Plastic all the way forward?
Postby N111YX » Fri Sep 16, 2016 4:01 pm
Bryan, I have read that pitot tube diameter is not too important. Come to think of it, my tube may in fact be a 1/4. I don't remember.
All of my P/S lines and fittings are nylo-seal brand, I believe. It's all TSO'd stuff and has not given me any problems in over six years now.
http://www.aircraftspruce.com/search/se ... GS&x=0&y=0
Bryan Cotton wrote:No worries Kip! Any thoughts on my 1/4" OD vs your 5/16" OD tube? I am thinking it is unimportant. Also did you choose the RH side for any technical reason? Finally I assume the plastic tube is from Home Depot's aviation aisle. Plastic all the way forward?
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1050 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby Bryan Cotton » Sat Nov 05, 2016 9:43 am
I have to confess I am tempted to use poly tubing. Has anybody else used the stuff for this application? It seems to last forever supplying water to the fridge.
Postby Bryan Cotton » Tue Nov 22, 2016 11:42 am
Kip,
What length did you settle on for your tube? Any science or experimentation to it?
Postby N111YX » Tue Nov 22, 2016 8:06 pm
I went with what looked "about right", Bryan.
That would be about 6 or 7 inches exposed and about 3 or 4 inches in the base.
If I remember, I'll make a little youtube video about it next time I'm at the hangar. Hopefully this weekend.
Bryan Cotton wrote:Kip,
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1050 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Postby N111YX » Thu Nov 24, 2016 11:14 pm
A short description of the pitot system...
https://www.youtube.com/watch?v=kKxCEWk ... e=youtu.be
Kip
Dynon D-180
Becker radios
Garmin GDL 82 ADS-B
1050 hours
48 states visited
Based near Atlanta
Also flying a...
N111YX
Return to Waiex
