142YX wrote:MichaelFarley56 wrote:Just mark new lines, grab the fly cutter, and use a wood base under the seat for support when you cut new corners. It's really not that bad.
Ill have to try this.. it was my thought that using a fly cutter after the hole had been cut would be problematic as it hits the edge of the pan with each pass.
Mike53 wrote:I would still probably turn it by hand but then I'm scared of sharp knives also :?
